I am wondering if a fax is failed to deliver from the api call or remain undelivered for some reasons, what is the correct way of detecting a failed fax.
Where will I find the details of those fax sent
You will find in call logs. It will be message status as"Queued" which means the message hasn't been sent yet. If you see the status as "SendingFailed " then it means the sending is failed
Sorry.. new to ringcentral.. where can I find these codes to determine?
Check the messageStatus in the response ... check the reference here: https://developers.ringcentral.com/api-reference/Fax/createFaxMessage
4 People are following this question.
