paul-jackson avatar image
paul-jackson asked
When Ihave a fax set up in softphone and select the edit original document option, I get "out of memory" message
I will have a document in edit mode to fax through softphone. I use the edit original document option which allows me to set up in paint to make changes to the document. I have a new computer that I downloaded ring central to and now I get out of memory message when I select the Edit Original Document icon on the menu
topic-default
