January Tidbits
SMS Questions Answered
You've got SMS questions; We've got Answers!
rajendra-prasad466 avatar image
rajendra-prasad466 asked Anirban Sen Chowdhary answered
how do I create appkey and appsecret
How do I create appkey and appsecret to use in our own application build using php?
topic-default
ak avatar image
ak answered
AppKey and AppSecret are found in the developer portal under the application that you have newly created.
Login to the Developer Portal (  https://developer.ringcentral.com/ ) using your RC Company Credentials and click on the "Application" you should be able to see the appKey and appSecret.
Also, take a look at our RingCentral Getting Started Guide here :
https://devcommunity.ringcentral.com/ringcentraldev/topics/ringcentral-developer-access-faq
Anirban Sen Chowdhary avatar image
You don't need create AppKey and AppSecret . It is automatically generated in developer portal under the application you created just like below:
