fige3631 avatar image
fige3631 asked kim commented
dont receive phone calls from poeple that are useing google voice
u.s type, i port my number from google voice to ring central, and i cancel my number at google voice, now my problem is, that when somebody which have a google voice number calls me in it says's that you are not able to take this call. what is the solution for this problem?
topic-default
fige3631 answered kim commented
***-1510
3 comments
Thank you. I'll look into this
We are going to make a few test calls.
We created a case for you to be escalated and troubleshooted. This well need to be looked at by our porting team.
Case# 04540514
thank you very much
No problem!
To update this case with further information or to check it's status please login to http://success.ringcentral.com/RCContactSupp  Select contact support , and you will be able to see view: all open cases at the bottom of the page.
kim avatar image
kim answered
This conversation is private so the information you provide is not public to the Community Users.
What is the Number you ported over to RingCentral?
