I replaced my firewall for a recommended one from Ring Central (Dell SOHO Sonicwall). In setting it up using the guide located here:
https://netstorage.ringcentral.com/guides/dell.pdf I see that there is a typo on page 15 (See the same screenshots but different descriptions? I figured that out and went on.
Then I was haveing QoS issues and decided to double check my settings. So then I used a different guide from Ring Central ( https://success.ringcentral.com/articles/RC_Knowledge_Article/7773 ) and noticed several differences from the SOHO Configuration Guide and this new Optimizing guide.
For instance:
As you can see I am quite concerned about which manual correct? For now, I am using the settings from the 2nd one listed.
Please advise.
For instance:
- Firewall settings are different for the Medium and Realtime for guaranteed and max burst.
- Network: RCFullRange4 and 5 are different from the config guide (See subnets).
- There are 2 additional IP addresses in the address objects list (RCFullRange6 and 7) that were not in the first manual.
Please advise.
