Hello.
When a call is parked using mobile or Windows app, and time goes by the parked call rings back on all devices that have the RC app installed on it. However, if the call was parked it means that we were unable/unwilling to talk with the other party.
We would like to be able to create an "Unconditional Forwarding" on all "Return Parked" calls so that a dedicated someone can be tasked with the call.
Is there a way to accomplish this?
I have tried creating a contact called "Return Parked" on mobile devices so that the contact name is in the list of contacts, however, when I go to import contacts into the RC app I hit the limitation LONG before the Return Parked contact is imported in. If all contacts could be imported in then I would be able to create an unconditional forwarding rule for all incoming calls with the Caller ID "Return Parked"?
Thanks!
tom
Thanks!
tom
