Speedway Wireless avatar image
Speedway Wireless asked Rahul G answered
Can't send SMS with spaces
I can send SMS with no spaces, as soon as I try to make a full sentence or even one space, I receive the error message,
"errorCode" : "InvalidJson",
"message" : "Invalid json in section [text]",
"errors" : [ {
"errorCode" : "CMN-131",
"section" : "text"
"section" : "text"
Here is my curl post.
"-X POST
-H \"accept: application/json\"
-H \"content-type: application/json\"
-H \"authorization: Bearer "& $token &" \"
--data {\"from\":{\"phoneNumber\":\"xxxxxxxxxx\"},\"to\":[{\"phoneNumber\":\"xxxxxxxxxx\"}],\"text\":\"test test\"}"
Any help would be appreciated.
sms
Phong Vu avatar image
Phong Vu answered Speedway Wireless commented
Not sure why your system does not work. This works fine for me
curl -XPOST https://platform.devtest.ringcentral.com/restapi/v1.0/account/[accountid]/extension/[extensionId]/sms -H 'accept: application/json' -H 'content-type: application/json' -H 'authorization: Bearer valid-access-token' --data '{"from":{"phoneNumber":"xxxxxxxxxx"},"to":[{"phoneNumber":"xxxxxxxxxx"}],"text":"test test and test again"}'
Can you try with "test%20test"
Speedway Wireless avatar image Speedway Wireless commented ·
I tried the "test%20test" but I received "test%20test" in the SMS message. I am using this in Filemaker if that changes anything.
Anirban Sen Chowdhary avatar image
Anirban Sen Chowdhary answered
This is something wired ... I never faced this issue.. Just see I am getting the response perfectly
Make sure you using correct Json POST request as below format and structure:
{"from":{"phoneNumber":"your phone number"},"to":[{"phoneNumber":"Your number to send"},{"phoneNumber":"Your number to send"}],"text":"Test message with space"}
Rahul G avatar image
Rahul G answered
Please check the phone numbers as well, it needs to be in E.164 format - Also, what is the error message you are facing? Can you elaborate?
