I am exploring ringcentral fax. I want to send PDF file attachment with rc fax through C# code.
Any example or pointer will be a great help
There are many way to do this with C# is to use (alpha) SDK which is available on Nuget and GitHub:
Check these reference: https://forums.developers.ringcentral.com/questions/8025/can-we-insert-a-pdf-document-to-a-fax-using-c.html
https://forums.developers.ringcentral.com/idea/332/new-webhooks-and-fax-demos.html
Instead of using the c-sharp SDK, which is obsolete, I recommend you to use the latest .Net SDK. And follow the example code below to send a fax.
// set the last param to true for production RestClient rc = new RestClient("clientId", "clientSecret", false); await rc.Authorize("username", "extensionNum", "password"); if (rc.token.access_token.Length > 0) { var requestParams = new CreateFaxMessageRequest(); var attachment = new Attachment { fileName = "test.jpg", contentType = "image/jpeg", bytes = System.IO.File.ReadAllBytes("test.jpg") }; var attachments = new Attachment[] { attachment }; requestParams.attachments = attachments; requestParams.to = new MessageStoreCallerInfoRequest[] { new MessageStoreCallerInfoRequest { phoneNumber = RECIPIENT } }; requestParams.faxResolution = "High"; requestParams.coverPageText = "This is a demo Fax page from C#"; var resp = await rc.Restapi().Account().Extension().Fax().Post(requestParams); Console.WriteLine("Fax sent. Message status: " + resp.messageStatus);
1 Person is following this question.
