PCIC Team avatar image
PCIC Team asked PCIC Team commented
RingCentral not reachable for Fax - Recurrences are increasing
We are facing issues related to RC not being available for Fax API.
Following is one example:
Response: StatusCode: 404, ReasonPhrase: 'Not Found', Version: 1.1, Content: System.Net.Http.StreamContent, Headers: { Connection: keep-alive RCRequestId: a02bf940-ea3d-11e9-9b97-005056afc229 RoutingKey: SJC01P13PAS07 X-Rate-Limit-Group: medi
Here is another one:
The remote host closed the connection. The error code is 0x80070057.
What is going on with this issue? Please connect immediately.
fax api
3 comments
PCIC Team avatar image PCIC Team commented ·
We have already looked through the docs and have not found any convincing answers. Here is one of them https://forums.developers.ringcentral.com/questions/281/fax-out-503-temporarily-unavailable.html
Phong Vu avatar image Phong Vu ♦♦ commented ·
Can you give me your app client id?
PCIC Team avatar image PCIC Team Phong Vu ♦♦ commented ·
GSMULQ2xSTevFxZIQloKbw
Phong Vu answered PCIC Team commented
I see that you have some successful fax API calls in the last 7 days. Isn't that you could send some faxes successfully?
I only see a few 404 responses from the get message-store and get content API calls. Can you double check to confirm this.
4 comments
Yes, there were some 404 responses. We would like to know why? The data sent in the requests are all valid values. Please let us know the reason behind the 4xx errors.
Phong Vu avatar image Phong Vu ♦♦ PCIC Team commented ·
What data? Can you post the content ID, the request you sent to the message-store or content API? Without seeing it, it is impossible for me to say why it failed.
Following is the fax request. RC responded with id1185180239028. However the request was set to sending failed. I have removed the data from "bytes" and "phoneNumber" field for readability and HIPAA requirements.
"attachments":
"fileName":"cover.htm"
,"bytes":""
,"contentType":"text/html"
"fileName":"1.png"
,"bytes":""
,"contentType":"image/png"
,"faxResolution":"High"
,"to":[
"phoneNumber":"xxxxxx"
,"sendTime":null
,"isoCode":null
,"coverIndex":0
,"coverPageText":null
PCIC Team avatar image PCIC Team PCIC Team commented ·
Following is another error logged today (in UTC). The error was logged in our system. Request Id is bolded and underlined.
Time: 2019-10-11 11:02:52.167
Error Message: Response: StatusCode: 404, ReasonPhrase: 'Not Found', Version: 1.1, Content: System.Net.Http.StreamContent, Headers: { Connection: keep-alive RCRequestId: ab728ae6-ec16-11e9-bb7d-005056af70d4 RoutingKey: IAD01P13PAS06 X-Rate-Limit-Group: medi
