andrew-auger13595 avatar image
andrew-auger13595 asked Byrne Reese edited
Receiving "unauthorized_client" error when using php curl for auth/token
  "error" : "unauthorized_client",
  "error_description" : "Unauthorized for this grant type",
  "errors" : [ {
    "errorCode" : "OAU-251",
    "message" : "Unauthorized for this grant type"
Here is my code below:-
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "https://platform.devtest.ringcentral.com/restapi/oauth/token");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, "username=+12048184079&password=Reset321$$&extension=101&grant_type=password");
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_USERPWD, "1RjNgM-LTxxxxxFuE-ggrHA" . ":" . "524fjcxxxxxxxxxxCPclIZHxxxxxx_FdfegzA");
$headers = array();
$headers[] = "Accept: application/json";
$headers[] = "Content-Type: application/x-www-form-urlencoded";
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$result = curl_exec($ch);
echo '<pre>'; print_r($result); die;
if (curl_errno($ch)) {
echo 'Error:' . curl_error($ch);
curl_close ($ch);
topic-default
igor-bebin avatar image
igor-bebin answered
Hi Andrew,
The following grant types are available for your application:
* Authorization Code
* Refresh Access Token
Please find instructions on how to use these flows:
https://developers.ringcentral.com/api-reference#OAuth-2-0
https://ringcentral-api-docs.readthedocs.io/en/latest/oauth/#authorization-flows
Thanks,
Igor
andrew-auger13595 answered Tyler Liu commented
can you correct my code or give me the exact code according to my php curl for this error
Tyler Liu avatar image Tyler Liu commented ·
If you want to use password flow, you need to create a new app which supports password flow.
Anirban Sen Chowdhary avatar image
Anirban Sen Chowdhary answered
The screenshot shared by you seems you have created application of platform type server/ web which supports grant_type=Authorization code while you are trying grant_type=password.
You need to create application that support grant_type,=password or password flow in ring central terms
