Raman Thakur avatar image
Raman Thakur asked Raman Thakur commented
Hi I want to create a WPF Application with C# where I need to integrate RingCentral API. Please suggest the process for the same.
apic#
Phong Vu avatar image
Phong Vu answered Raman Thakur commented
Hi, check out the dev guide to learn how to use the RingCentral .Net SDK in your C# project. Let me know what APIs you want to use or what communication features you want to integrate into your app.
Raman Thakur avatar image Raman Thakur commented ·
Hi Phong Vu,
Thanks for your suggestion...
I want to call the phone number of a customer listed in my WPF application using RingCentral API. What are the process which will I follow for the same.
I downloaded RingCentral.Net through nuget and it's working fine in case of console application as suggested but the same code will not run when I implemented it at my WPF dummy application.
Also is it possible to open ringcentral dialer pad with WPF application. If it is, then what are the steps which should I follow for the same...
