Stephen Kamin avatar image
Stephen Kamin asked Stephen Kamin commented
Phone does not ring and unable to answer incoming call after I transfer a call
I receive a call... I transfer said call to another phone...
Another call comes in ...and here is the issue...
MY phone does NOT ring nor can I pick up the imcoming call...
I pick up my extension, press one of my open lines, press an extension that is ringing and my phone actually places a call and rings everyother extension in my group like I place a call...
Some other extension has to pick up the incoming call and transfer it to me...UNTIL my original call (which I transfered ) disconnects ... then all is back to normal.
topic-default
Stephen Kamin answered Stephen Kamin commented
I just noticed the RingCentral Release Notes | April listed all of my above issues as resolved..
"Resolved: issue that prevented receiving new calls after transferring a call from the Softphone."
(my issues is not  from a smartphone but same issue)
"Resolved: issue where under certain conditions Agents appeared "busy" on the web when they should be available" (I am unavailable until origianl call is ended)
Stephen Kamin avatar image Stephen Kamin commented ·
here is a screenshot from 10 minutes ago... my extension is 1002-
I am currently NOT on the phone-
I answered a call and transferes it to x101-
The call is still active- and it has been for 7 minutes-
