david-prioriello13036 avatar image
david-prioriello13036 asked jessicahernandez16518 answered
Salesforce Call Center Login failure Sorry, we can't recognize the device. Please use other device or browser and try again.
I can't sign in to my Salesforce Ringcentral Sidebar app integration due to some kind of 2-factor sign-in problem. I receive the code in my email but then it doesn't work.
topic-default
jessicahernandez16518 avatar image
Hi David,
Are you experiencing this problem when using a different browser, such as Google Chrome?
david-prioriello13036 answered
it looks like I have the same problem in chrome.
Hi David,
Can you make sure you have AdBlock turned turned off in your browser, it's possible that it is blocking the iovation library for 2-factor authentication. If this doesn't do the trick, please open a case with Support!
